Damo666
Hi Guys,
Had a look at a job today and need some help, the shop has three roller shutters all going to seperate up/down switches (NEXT TO EACH OTHER) all with 3 core plus earth inside, i cant see any other cables without moving the displays, the customer would like an isolation switch put in next to the switches so one switch will isolate the three shutters, can anyone tell me what i need to do / find and any help on how these shutters are wired would help
thanks in advance cheers lads
What about a 3 pole switch?
As used for fan isolation in bathrooms.
Put each of the feeds to the up/down switches into the 3 pole switch.
could use a 4 pole contactor. one coil, 4 N/O contacts. gives D/P isolation
Again depends on the arrangements in the supply end, if its fed from seperate breakers i wouldnt be happy grouping them all in 1 switch, hence i diddnt suggest using a 3ph contactor.
We don't know that the shutters are fed from different breakers although I can't actually see that that would be a problem, unless they were on different phases.
this job was done by a local sparky who has since gone outta business its single phase all fed from one mcb, but looking at other circuits in the shop nothing would surprise me
HELP with electric roller shutters in a shop
Electrician Talk | All Countries
Damo666,
Steve1412,
