Search the forum,
Discuss Hoping to identify the wiring on this 240v Table Saw motor in the DIY Electrical Advice area at ElectriciansForums.net
If it's single phase there'll probably be a capacitor associated with the motor, and although unusual, it could be remotely connected on those two black wires.
Where are the resistance measurements?
Not being completely sure what resistance measurements were required (not really sure what I'm doing here), I took the following
Black1 > Black2 >1.6
Black1 > Grey > 2.4
Black1 > Blue > OL
Black2 > Grey > 2.2
Black2 > Blue > OL
Grey > Blue > OL
Black1 > Black2 > Continuity
Black1 > Grey > Continuity
Black2 > Grey > Continuity
Not the others
Does that make any sense?
Black1 > Grey > 2.4
Black1 > Blue > OL
Black2 > Grey > 2.2
Black2 > Blue > OL
Grey > Blue > OL
Not the others
Obviously Not!
Can't really make much sense of it, TBH. The resistance readings only make sense if they're connected in a delta or star arrangement, and the blue doesn't appear to be connected to anything (possibly to a centrifugal switch? or just faulty winding?
Or maybe it just burnt out.... thanks for replying.
Reply to Hoping to identify the wiring on this 240v Table Saw motor in the DIY Electrical Advice area at ElectriciansForums.net
i had a 3 speed blow motor to an AC fan coil unit. I disconnected the wiring and installed a new unit and forgot how the wiring goes, i no expert...
I need to connect a replacement motor for a septic tank agitator. I've identified that the motor needs to be connected to a 4mf run capacitor but...
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
Hi all I have a small DC motor that I pulled off from an ABS car module and need help identifying some parts in order to hopefully rebuild it. 1...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
