C
Cooper_day
Hello everyone,
Need some advices to be fair. How do you charge for remedial works after an EICR did not pass? Are you charging on a daily rate?
Thank you
Usually an hourly rate (if the remedials are very straightforward then perhaps an estimate instead).
Usually an hourly rate (if the remedials are very straightforward then perhaps an estimate instead.
We looking at two lighting circuits and one ring with low reading on insulation resistance as main issues. Basically all lights around the house needs to be investigated.
Anything that needs investigation is always an hourly rate, for as long as it takes.
Today I was investigating a socket circuit with low IR, there are at least 3 separate issues (so far), including a damaged SWA cable connecting a summer house, and T&E encased in mortar on top of a garden wall with a suspected encased junction. I'd never give fixed prices for this sort of work.
I tend to work hourly , I find this the fairest way and means the job has a cut off point if you simply can't get to the bottom of the issues
I know some people who will literally 'price' everything , but I don't see how you can price say fixing a broken a ring. Unless you just blurt out say £250 to find and rectify fault....
