Discuss How much space to set aside for DNO in the UK Electrical Forum area at ElectriciansForums.net
dellboy13
Hi
Just to make sure I have this covered, how much space do the DNO & provider normally require for the fuse unit and meter? And what is the preferred height?
KR
Mark
Have you already agreed the meter position with the DNO? Most DNO's require the meter position to be external. Some exceptions though, but best to sort out position with them first.
The house is not built yet but I have had a quote for install from the DNO and they are fine for it being installed internally as the new build is being very much controlled by the Conservation Officer as it is between 2 listed buildings and he would not allow me to install a white box on the external wall. The install is a 100A single phase.
Last few new supplies we did they sent us drawings, past three have all been internal. It's good to have drawings as the installation teams have mood swings and having it taped to the wall keeps them quiet.
Usually, when installed internally, the DNO require the meter position installed on the inside of an external wall. If going internal U/G (with their approval) a short distance a black rigid pvc duct will be required. As said above get it in writing.
Reply to How much space to set aside for DNO in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
On another forum for general EV chat this question comes up all the time. It's very common to install a charger taking the supply direct from the...
We had a new supply installed this week. DNO installed new cut out and fuse externally. Meter operator sent his engineer to move the meter in the...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
G99 GSI-3 4.4 kw Victron inverter install with EES and batteries and installer can set the export lint if required by dno As part G99 GSI-3 you...
