I have a panel transformer with the input options of : 415V 220V 0V and output options of 110V. I’m using this so the control panel will run 110V and not 415 or 220. I have a three phase supply and how would I wire this into the transformer and also how do I wire the output. Where does 0V go and what do I use as a neutral for the circuit ? Thanks
The primary and secondary connections should be self explanatory. What is the purpose of this transformer and your involvement.
Panel wiring for work. Just wondering if 0V is used as a neutral through the control circuit ( 0V on secondary) and if I connect up to the primary with one phase (240) do I need to connect any other wires or just live
As Westwood and,
You are modifiying or building a control panel, this means you own the design and become responsible for any future issues.
The questions you ask suggest you don't have the knowledge or experience to carry out this task.
UK
United Kingdom
How to wire a panel transformer
UK
Jamiehasadog,
ElectroChem,
