Discuss Identifying BS88 fuse? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
Stormflex
Main fuse carrier says 100A 415V BS88 1967 on it.
Looking in OSG page 57 for short-circuit capacity there is a BS88-2 and BS88-6.
How do I know which I have?
Rich
BS88-2 are common, renames BS1361 as far as i can tell. 16kA.
Thanks - 50kA is my answer then.
Now I've just got to try and figure out some of the cable sizes. Lighting and sockets easy. Think the cooker looks like a 6mm!
If you cant ID the main fuse model, then i would i assume it to be the one with the lowest breaking capacity and record that. As long it is below the PEFC / PSCC measurement its not that important in my mind. As most PEFC/PSCC readings are below 6kA it should be OK. As someone has already said it has been renamed BS1361 in almost all domestic situations, and that is what i always use with the odd exception anyway.
Cheers........Howard
Reply to Identifying BS88 fuse? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, With regards to modelling a multi service distribution board, how would you guys model it in Amtech? I have tried using a TPN...
4K
Hi, I have a book on domestic wiring which says that everywhere there is a change in current carrying capacity along a circuit there must be some...
Hi, I have recently bought a house and I have a fused switch in my living room which I don't know what it's for. I believe it was a switch for a...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
