Discuss Install new R F Thermostat reciever. in the DIY Electrical Advice area at ElectriciansForums.net
A
Ajt
Hello I'm new to the forum and this is my first request for some help and advice please.
I have a present a manual Honeywell room thermostat..
i am wanting to change this for a RF thermostat and reciever as I'm disabled and will save me having to go into another room to turn on the heating as that's all the present wall thermostat does.
old/the present room thermostat with only three wires Red=live/blue=neutral/yellow=?
This is the new RF thermostat reciever that has four connections..
Wiring diagram for reciever.
I can see that there is a connection for the live and neutral and two other input connections..
I have connected live and neutral (red-live/blue-neutral) and tried yellow wire in NO and COM the thermostat clicks on and off when I adjust temp on hand thermostat unit but heating does not come on..
any help or advise would be most appreciated.
Ajt.
Welcome to the forum Ajt :)
I have approved your post for the general forum for the time to give a quicker reply, when Admin' are next on line you may be given DIY status and the thread relocated, this won't effect any posts already made :)
The yellow is the switch live to either the valve or boiler depending on what system you have. Is the new thermostat programmable? And do you have an existing timer/programmer for the CH?
Hi thanks for replying..
No it's a simple unit just turns on heating using the hand unit..it's simply temp up and down to turn the heating on or off via RF unit so I can turn on heating from my chair sort of thing.
'yes I have an excisting timer programmer that is just set to ON and not touched ever as I use the room wall thermostat I want to change to RF one to turn heating on or off or at a set temp on dial.
If the original thermostat is controlling a 230v heating valve,connect the red wire to the L terminal, connect the blue wire to the N terminal , link the L terminal to the C terminal and connect the yellow wire to the NO terminal
this is assuming the blue wire in the original thermostat is a neutral cable
But if the thermostat is connected to a programmer/timer then it would have to be set to constant/override. If this was the case id rather connect the receiver directly to the wiring center so there wasn't two timers in series.
I am only working on the basis of the RF unit being a direct replacment of the thermostat,I am assuming there is a transmitter somewhere sending a signal to the Reciever
Receiver would need fitted where current stat is, then programmer would either need bypassed or set to permanently on for that CH Zone.
My understanding from the OP, is the RF thermostat is being located in a different room sending a signal back to the Reciever at the original stat position , and as such the original control strategy has not changed
I understand what you mean but the live supply to original stat position could be via a programmer. If new thermostat is programmable then what 123 said.
Reply to Install new R F Thermostat reciever. in the DIY Electrical Advice area at ElectriciansForums.net
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hello, I have a regular boiler doing room heating only, with a Drayton programmer (for time) + a Drayton dial stat (for temp). I've bought a...
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
