geordie
Hi all
I have been asked to supply and fit 6 downlighters from the ceiling side of a living room, doesnt look too complicated and doesnt need to be low voltage. How much would you charge for this job? Im just a bit unsure.
i would say about 60 pounds materials, 100 pounds labour. It should only take you half a day max to do that.
Firstly work out the cost of the down lighters ,down lighter junction box ,HR flex , type of down lighters ,halogen CFL or LED ,i always use fire rated one , you are required to do this if an occupied room above, then estimate how long it will take and muliply this with your hourly rate
so if you had say pendant in the room would you just start from there. how would you leave ceiling? for someone to skim or are you neat enough????
If you are cutting holes for the down lighters and there is loft space above ,pop up into the loft and measure the ceiling joists and between them then transfer the measurments to the ceiling this way you can set out the lights and miss the joists nothing worse then a ceiling full of holes due to hitting the joists
oh and duram and jason are spot on with the costs £40 - £50 easily unless you use the nice Halers then its £50 just for the fitting no heat no lamp replacement !!
I hope your intention is not to notch the joists on the underside, as this practice is a contravention of Part P of Building Regulations (EGBR 2.3.2 and OSG 7.3.1) and structurally dangerous.
could make huge holes in ceiling, drill joists, feed in cable, patch ceiling, get the ceiling skimmed and redecorated fit downlights. total cost of job £1950, or notch joists underneath and make good with filler after fitting metal cable guards. job done for £300
geordie
Teesside
Website
http://www.northelectrics.co.uk
United Kingdom
Business Name
North Electrics Ltd
Installing downlights - what to charge?
Business Related
geordie,
Voltimax,
