M
monkeyelectric
You could install a lockable rotary isolator in the circuit, is it a ring final Or radial?Here's one for you. In a foster home for naughty boys the client has a requirement to be able to "remove privileges" of TVs/PCs etc when necessary. They seek a means of doing this without having to get staff to use the Distribution Board. Would a DP switch of the correct capacity be the best solution. Are there any other considerations?
