Currently reading:
Jokari cable stripper
Discuss Jokari cable stripper in the Electrical Tools and Products area at ElectriciansForums.net
Got given a yellow round one that strip 2.5, 1.5 and 0.8 cable. Taken a bit of getting used to but once mastered, stripping insulation off is a doddle :smiley2:
Why not use a proper Electricians Knife? £7 in the wholesalers best bit kit I have in my tool box/bag, oh sorry it's not the latest toy is it? lol
Because there blunt as a butter knife.
I shave with straight razors and irwin blades are sharper than any cheap knife ive come across
Well sharpen them had mine for eons give it a rub on the stone every week, the knife I mean just the biz
I got a replacement from a wholesaler in Northampton "midshires" I believe it was CK I'll check later and let you know, off to The John Radcliffe this morning so not at work.
Yep it is CK got "Electricians lock knife" stamped on the handle
electricians knife
The best knife I've ever owned is a Japanese made knife by a company called marvell they're expensive but real quality good thick blade great for stripping t& e very sharp for fp not pointed so you can't stab the apprentice when you lose your rag. Better than any jokari gimmick
I've had one for a while but never really used it. Tried it out last week on wire armoured and some flex and worked well. Very quick. Had 16 ends to make off and it did speed the process up. I think mine was £10 from eBay can't remember the number thou.
Got one of them as well I'm a proper bloody magpie, if it looks nice and not too expensive I'll have it, may grow up one day
I could get you one of these for as little as £20 XD
mirror finish
I've got a jokari stripper and it is handy for stripping the inner sheave of SWAs if you've got a big DB to second fix, just make sure you set the depth correctly on a excess bit you don't need (bear in mind that sometimes the inner sheath changes depth as it goes round the cores)
Reply to Jokari cable stripper in the Electrical Tools and Products area at ElectriciansForums.net
