M
Mattp9394
Hi all, i have been on this forum for a while now reading and learning but not saying a lot so now is the time for change.
I have been given the task of correcting the unsatisfactory periodic inspection report by doing all the corrections and updates to the installation.
I have two questions about this:
First one:
The cu is an old square D unit that is laied out from right to left:
main 100a switch, 40a(will be a 32a), 40a(will be a 32a), 6a, spare, spare, spare, rcd(two slots), 6a, 32a, 32a, spare
because of the cables buried in walls >50mm rule all the circuits need to be placed on an rcd. My question is can i get away with addapting the board with a kit like this SQUARE D 63Amp 30Ma 1P+N RCCB SWITCH DISCONNECTOR SPLIT LOAD KIT DOM63R30KIT2 | eBay
or do i have to do a whole board change.
second one:
when i have done all of the problems/made it a satisfactory state, do i just teat the work that i did or does it need to have another periodic inspection done on the property.
By the way there are no faults on any circuits, its just incorrect bonding and undersized tails and incoming earth etc.
any feedback is greatly appreciated.
First one:
second one:
