Search the forum,
Discuss Key switch for emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Nice simple layout for non-maintained emergency lighting - three landings and one exit. As it's the first time I've put in emergency lights I was wondering
1) Do I need a key switch for each light or just the whole system?
2) Would the requirement to run off the local lighting circuit be met by by just coming off the same RCBO?
i'm a bit wary of putting em's on RCD, even if it's RCBO. a fault on the lighting will take out the em's.
Due respect, thats what they are there for, any failure or fault will bring on EM lighting, and save someone neck
agreed, tazz, as long as it's a frequently used circuit, so that a fault would soon be noticed and corrected.
Post deleted as im talking rubbish.... :)
Would hope so...but saying that some of these landlords we meet, wont even change lamps
Always use same lighting circuit, if a rcd goes on the lighting circuit, and your ems are on another...chocolate teapot time
Reply to Key switch for emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
