Discuss Kitchen Mains Circuit? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
So you may need a new dedicated circuit for the cooker too
Yeah I already assumed that for the cooker.
Although I just checked the cookers and they are on 13 amp plugs? that would mean 3kW? really?? that low?? I thought they would be up with showers >7.5kW.
But I guess either way 3kW would be another high power unit on the circuit, so then the kitchen circuit could potentially have Cooker, Dishwasher, washing machine, dryer and kettle going at once whic sounds a lot! I suppose this applies to all households though
So cooker on its own would take a load off
From my experience, B&Q will use electricians registered with NICEIC (not a prerequisite for competence, just 'cos their registered), so they would suggest a kitchen installer would not be doing the work.
As suggested, RCBO for new 'Ring Circuit', be you may need to check compatibility of new Hager RCBO in your 'fuseboard'. And as kitchen designers often do, you new cooker/oven will probably be relocated to the other side of the kitchen, which also may require RCD protection for new buried cable route. This could be accommodated in the existing RCD, but the 'Division of Installation Police' may be along in a minute to quash that idea. Earthing & bonding might need upgrading, although looking at your fuseboard & notices near it, that might already be in place.
Suffice to say, you need to get a competent electrician in to advise you.
Yeah I have contacted some Electricians to get quotes, using the information everyone has provided me on this forum, I will ask the relevant questions. If I state that these various options then at least he will know I have a better understanding of what should and should not be done
Just don't be tempted to do it yourself :) And as I think's been mentioned, as it looking at a new circuit, it will be notifiable to your local building control. So you electrician will need to be registered with a government approved scheme (there are 2 other options).
Yeah sorry in my brain cooker = oven
Will be electric oven and gas hob. because electric hobs are rubbish!
As you will be having a dedicated socket circuit for the kitchen and even though the oven of choice at this time mauy have a 13A plug the fun will start as and when you change your mind, however if you have a dedicated circuit run in for the oven you buy yourself much more flexibility in the long run.
Absolutely... I would not take on this task as there are way too many regulations to follow... I would only stick to changing light switched and socket covers
Reply to Kitchen Mains Circuit? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
For some Strange reason we have three Circuits running in the Kitchen i think for two OLD Cookers and a Ring Circuit for the house. Well the...
Bit of advise if anyone has time.. I have a customer who brought a new kitchen from wrens. Customer has had the route to the kitsch redecorated...
