J
jpread988
hi all,
which of the following appliances require there own radial feed,
washing machine
tumble driyer
fridge/frezzer
boiler
under the 17th edition do they require there own switched spur and do the sockets need to be eatched with the name,
these are about 10m fron the consummer unit, is 2.5mm with 20a mcb okay or should it be 4mm
kind regards and thank you for any help
jamie
hi all,
washing machine
tumble driyer
fridge/frezzer
boiler
jamie
I would guess non of them?? but then again i'm no electrician !
I usually always wire the boiler seperatly, and any normal sized kitchen, wire it on its own ring.
