Hi Snowhead, our bills have gone up 1200%. The Ombudsman has ruled in my favour regarding EON's handling or lack of it, but now we need to address the meter error. Knowing what the Error code means might help our case. Its dated 2004The fault will be an internal issue with the meter, like failed comms or unknown command., there will be nothing you could do about it if you knew what the fault code indicated.
It's most likely the meter would be replaced.
The Meter model number doesn't bring anything up on searching, do you have a photo of it including any numbers on it?
Also are you being billed by the supply for energy use?
Typically meters are owned by a third party company and sometimes installed and maintained by yet another company other than the supplier.
The energy supplier will lease the meter.
Have you complained to OFGEM about the lack of response from your supplier?
Found this - (sorry two out of sequence pages pasted below)
Click the thumbnails to read them!
🥇 ProtectedPool ➤ Most Powerful and Safest Web3 Smart DeFi Wallet 🔐
🥇 ProtectedPool ➤ Web3 Smart DeFi Wallet 🔐 . Your New DeFi Experience:: 🔐 Secure, Smart, Simple. Double Approvals. Add extra confirmation of any transaction with 2FA solutions including Google Authenticator or hardware security keys. Self-custodial Solutions. Protected Pool is built on smart...docplayer.net
View attachment 106723View attachment 106724View attachment 106725
I don't know! It probably does if you are planning going to a court of law!Does it matter that mine is 120A and this is 120AP?
Will do. ThanksI don't know! It probably does if you are planning going to a court of law!
The manual is dated 2001. Your meter is 2004. I think it's likely the structure and meaning of fault codes would remain consistent during continuing development of the product over 3 or 4 years. In your position I would assert that the L&G documentation indicates the fault code displayed indicates a failure in the meters measuring system, and see where this gets you!
I see there are documents on the web under Landis & Gyr "ZMD120ASer53". Good luck!!Will do. Thanks
I could not find any, could you supply a link please? ThanksI see there are documents on the web under Landis & Gyr "ZMD120ASer53". Good luck!!
Thanks. But my display does not follow that format, there is only 1 F and no space between F an 1st 0. Must be a difference between 120Aser53 and 120AP??? 7 digits not 10.The ZxD120AP meter doesn't use the first 2 digits of the display for faults, so the DFS fault is wrong,.
The error FF 04 00 00 00 indicates a clock fault from self test, it could mean there is a failure of the internal clock so any timed Tariffs could be wrongly recorded.
However in all the L&G documentation I've seen online they always say if errors are displayed remove the meter and return to a service centre.
Eg LANDIS GYR ZMD120ASER53 (Mode d'emploi, notice d'utilisation & manuel de service) - http://www.manuels.solutions/commander_document.php?ctexte=LANDIS%20GYR%20ZMD120ASER53I could not find any, could you supply a link please? Thanks
Thank you both for all your help.I did come across the manual showing the larger number of display fields, but didn't consider it was necessarily correct for the ZMD120ASer53 model.
I noticed there is a meter selling on eBay with a similar, but different ('Ser' is 'Ptr') model no here:
interestingly the seller pastes a link to the manual in his listing, the same as the one in my post #4 !![]()
COMPTEUR ELECTRIQUE SIEMENS LANDIS+GYR DIALOG ZMD120APtr53 | eBay
Find many great new & used options and get the best deals for COMPTEUR ELECTRIQUE SIEMENS LANDIS+GYR DIALOG ZMD120APtr53 at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
