- May 8, 2023
- 4
- 1
- 33
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United States of America
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
I am lighting my workshop with LED's. I had all 13W (1500 lumens) but wanted more light on the benches, so ordered some 23W, which is supposed to be 2500 Lumens, The 23W seemed only slightly brighter than the 13W, if at all, so I tested with a "Kill a Watt" meter. The 13 W showed a true 13 watts, but the supposed "23W" only showed 17 watts. There is a button that sets the meter for either "watts" or "VA" and I set it for watts. I should see a substantial difference between the 1500 lumen bulb and the 2500 lumen bulb, but I tested them independently in separate holders and am not even sure one is brighter than the other. Both are in the 5000K range of light. I sent the first batch back because they measured on 16 watts. No company name on the bulb, and, of course, made in China. My real question is: shouldn't the 23W bulb measure 23 watts on the kill-a-watt meter? I am trying to get a battery for my old camera to use its light meter, but the results won't be in lumens.
