whatts
kenai peninsula AK
United States of America
I am lighting my workshop with LED's. I had all 13W (1500 lumens) but wanted more light on the benches, so ordered some 23W, which is supposed to be 2500 Lumens, The 23W seemed only slightly brighter than the 13W, if at all, so I tested with a "Kill a Watt" meter. The 13 W showed a true 13 watts, but the supposed "23W" only showed 17 watts. There is a button that sets the meter for either "watts" or "VA" and I set it for watts. I should see a substantial difference between the 1500 lumen bulb and the 2500 lumen bulb, but I tested them independently in separate holders and am not even sure one is brighter than the other. Both are in the 5000K range of light. I sent the first batch back because they measured on 16 watts. No company name on the bulb, and, of course, made in China. My real question is: shouldn't the 23W bulb measure 23 watts on the kill-a-watt meter? I am trying to get a battery for my old camera to use its light meter, but the results won't be in lumens.
above my workbench i have installed a 2' x 2' 40watt panel LED unit (designed for use in a suspended grid ceiling). more than adequate.
Reactions: pirate
I'm with Tel on this...a 600mm square 40 or 50W panel will be plenty, will work for ages, and give you plenty of light if you position it correctly
I think LED lighting is still evolving as we can now buy LED lamps at a lower wattage today than 3 - 5 years ago but the luminous output has gone up.
Bringing colour rendering (k) into the equation brings even more variation.
So don’t pay too much attention to the wattage (which being LED can be pretty insignificant these days) when designing to a specified lighting level.
My problem is this supposed "23w/2500Lumen" bulb doesn't seem any brighter than the 13w bulb, so I'm guessing my reading of 17w is correct. I bought these through Amazon and some of their suppliers "misrepresent" a lot. Thanks for the reply.
Yes the wattage is often exaggerated on non brand bulbs, the same csn be said of non branded lithium batteries where they make up the capacity. If you cave a light meter you could check but just stick to branded bulbs and you should be fine.
Reactions: nicebutdim and DPG
There's rarely a direct correlation between energy consumed and light emitted
A manufacturer's claim of 23 watts should actually test at 23 watts.
I'm closing the thread here. I did thorough testing with a light meter, different angles, direct, different bulbs, and have come to this conclusion: the so-called 23w 2500 lumen led bulbs being sold through Amazon do not put out any more light than my 13 watt led bulbs. Also, they are much lighter in weight than comparable led bulbs I have bought in the past, and I doubt that indicates improved technology; more than likely cheaper/missing materials.
Reactions: suffolkspark
The quality of some things sold by on line retailers varies a lot. I definitely wouldn't rely on the figures given. If you want to be more certain then buy from a proper electrical wholesalers and buy a known brand.
I don't think anyone doubts that goods of unknown provenance may fail to meet advertiser's claims.
In the UK such matters would be handled by Trading Standards. If a similar body exists in the US, they would be the best people to raise this issue with.
Edit: the real issue is not wattage, but light output. If the lamps in question produced the claimed 2500 lumens, then lower than advertised power consumption would be considered a bonus and you would never have felt compelled to investigate.
"Bought these cheap on Amazon" - Lost count of how many times I've heard this, and how many times/have problems!
This could only be a nominal figure as variations in voltage and load will clearly affect the figure of 23watts you are expecting. We work to a nominal voltage of 230v but rarely is as a tolerance of +10 and -6% is permitted.
kenai peninsula AK
LED bulb true wattage
Lighting Forum
whatts,
DefyG,
