Q
Qadeer
Hi,
In my room 2 Led round ceiling lights are installed, week ago both were fine, but now when I turn on both lights, one starts flickering, even their emitting light is getting low...
Is it switch problem or LEDs needs replacement?
Hi,
Are they both on the same switch? If so then it's unlikely to be the switch, unless they are wired separately from it and there is a loose connection behind it
Or are you saying one flickers only when the other one is on?
It may well be the LED driver is giving up, which is often built into the light fitting these days so needs a new light fitting. It could also be a loose connection on either live or neutral though.
In either case, it should be less than an hours work for any competent electrician...
Led ceiling Lights - one light Flickers when other is switched ON
Lighting Forum
Qadeer,
Admin,
