J
JD Hogg
Does anyone know of LED downlighters which have easy connect terminal block such as the JCC Fireguard but without the high cost?
The standard choc block type connector is a pain to loop a couple of 1.5mm T & E cables into whilst ensuring no brown or blue insulation is showing outside of the connector. Downlighters such as the JCC have a very easy 6 terminal push fit connector which takes seconds to conect into.
So the JCC are more expensive to buy but cheaper to install - whats your problem?
