Discuss LED GU10 in IP65 fittings externally in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
GU10 LED lamps fitted externally in IP 65 fitting
Hi, anyone know or had an issue with LED GU10 lamps in an external fitting failing?
Fittings installed with lamps last year, job been delayed with Covid, just started to power up and find half not working, they are twin up/down lighters, most of the ones not working are the uplighters, can winter affect these?
Also have a similar issue with 20w LED floodlights, (time guard) that a large percentage of each fitting are out. Again new and first powering this week.
I have two ideas, winter? ! or someone has tested cables at high voltage and blown LEDs, appreciate and ideas.
TL;DR
GU10 LED lamps fitted externally in IP 65 fitting failed
Are the floods pointing up?
I watched something, can't remember where, that explained the failure mode when LED floods point up.
Water pools around seals and seeps in and freezes opening the seals.
Don't know what's going on with the GU10s though.
Hi, many thanks, Bought the LED GU10 lamps separately, from the fittings. Yes the fittings are fine, work with a replacement lamp. The LED floodlights are all pointing down, no sign of any water, damp in any of the fittings.
Reply to LED GU10 in IP65 fittings externally in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hill hope you can help. Need some advise or advise me on how to install a PIR LED floodlight as a new installation. We are wanting one fitted...
15K
M
Hi All I am about to undertake my first job installing outside lights for the signage on a retail outlet. I need to get this bang on because it...
4K
MBEINST
M
