SIIVION
Good day.
Recently I have installed 26 1200 x 600 LED light panels, the customer now complains they flicker. As per usual with this sort of thing when I visit there is no flicker. It can happen 6 times a day or just the once.
I have researched the possible causes, poor quality drivers are most likely the culprit.
Can anyone recommend good quality drivers please?
TA
could be some hefty loads switching on in adjacent premises, like motors etc.
Yes poor drivers are the most likely problem,
Because Led's react quite quickly, you will see every dip or peak in the supply,
The only way to fix this is to put some LARGE electro's on the drivers,
Or source better quality drivers.
led light panels flickering
SIIVION,
nickblake,
