Discuss LED light strip with motion sensor for bathroom mirror backlight in the Lighting Forum area at ElectriciansForums.net
Hi,
We are doing a bathroom renovation and I can't find a light or a mirror with light that I like. I would like to buy a simple mirror that suits the style I am going for with a wooden frame, and then mount that mirror on a MDF background slight smaller than the mirror. I would like that MDf background to have an LED strip going around it, hardwired into the place the 50s vanity light is at the moment, with a motion sensor at the bottom for switching on and off. I was thinking products like the below. Can you tell me if these are what I should be looking at, and if it's a suitable thing to do for a bathroom mirror? It's not an idea that seems to sit easily with our electrician so I wan't to check I'm not asking something ridiculous. He said it would be a question of trial and error but I'm not sure why, so would like advice on where to start off.
  • 3_252Fc_252F3_252Fb_252F3c3b12b17325fc25bba7d86860d48bec22e3ab44_LST60CW_large.jpg
Reply to LED light strip with motion sensor for bathroom mirror backlight in the Lighting Forum area at ElectriciansForums.net
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
Hi All I have recently had a new bathroom mirror installed with a built in LED and Demister that is turned on using a motion sensor. The mirror...
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
Next week I'm starting to build a few built-in wardrobes for the bedrooms and I've hit a brick wall on the lightning element. Normally I run 1.5mm...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
