Discuss Led strips in the UK Electrical Forum area at ElectriciansForums.net
S
schoe
Just a quick one I'm looking to install these in a kitchen under some units, I want to wire them using a switch on the wall, however every website I've seen shows them wired with a plug, is it possible to wire them using conventional wiring or do they have to have a plug on them?
thanks chris
I'd like to wire them on a 2 way circuit ideal, the only way around removing the plug I can think of is by cutting it off then wiring it into a switched fuse spur.
Thanks huntos, how did you wire them up? Did u run power into the driver then take the switch wire out of the driver as well? Thanks chris
Switch wire and neutral to the driver, then you buy fly leads which push onto the led strips and conect into the driver, your local wholesalers should be able to help, I bought it all as one kit but I had a lot to install so may not be the cheapest option for a few in a kitchen
Reply to Led strips in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
