N
Netherspark
I hope someone can help me understand this. I've just replaced both my florescent tube lights with Energizer LED tubes, and they were fine for about a week but last night the starter fuse in the kitchen light blew. This afternoon I swapped in the starter from the other light and it too immediately blew!
These are the kind of basic replacement tubes that fit into existing ballasts, just requiring you to swap out the starter for the new LED fuse. This one:
www.lampshoponline.com
The fuses are rated for 250mA.
Is there something wrong with my wiring? And if I replace the fuses, should I get a higher rated fuse, and if so what amperage should I aim for?
Energizer T8 5ft 1500mm 22w Led Tubes 4000k - LampShopOnline
Buy Energizer T8 5ft 22w Led Tube Frosted 4000k (High Output) at LampShopOnline. LED tube replacements for 5ft fluorescent tubes. Save up to 60% energy by changing to LED today.
