From DW .... The supply wiring you bring into the fitting is subject to BS7671 and i can't believe an inspector (*) would not know the difference now if you had 1mm lighting cables on a 10amp mcb it is quite likely the comment was aimed at your cabling needing to be 1.5mm. NOPE!!
Afraid not DW, the design was for ALL wiring to be 2.5 in the building. I kid-you-not they have pulled up internal wiring (the manufactures wiring) for being to small to tubes.
A few months ago you kindly answered my question on internal wiring which was based on these idiots interpertation of the Regs.
(*) one inspector turned out to be a cable TV installer. HR accepted his 'card' as it had the word electrical on it, so he became a company electrical 'inspector' !!
