While doing a EICR I found that the lighting circuit and the socket circuit in the flat are fed from different CUs.
The job is in a residential home.
Different Phases, or all on the same phase?
Are the boards clearly marked or associated paperwork, also anyone isolating the sockets/lighting should be following normal safe isolating procedures so what risk do you see here?
It is common on larger building to have a dedicated boards for power and one for lighting, it's just not common on the domestic scene.
I see no issue if the boards are clearly marked and the circuits are otherwise safe and compliant.
Thanks for the feedback guys, I am going back on Saturday and will check. There have been a lot of add ons over the years.
Pete I will have to confirm if the CUs are on the same phase.
OK cheers
Swansea
United Kingdom
Business Name
Michael Jones Electrical Inspection
lights and socket outlets in the same room fed from different CCs
Michael J,
westward10,
