Discuss Location for main electrical panels in new construction in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a general question about main panel locations. The house is 120' long so I was contemplating running 2x 200amp panels located on the exterior of the house as marked in the attached photo. The main service and meter is on a pole outside. I had planned on running a trench from the main panel to the pole and feed the sub panel from the main. Alternately, I was contemplating running one or both panels on interior walls and run conduit through the slab. What are the positives and negatives of doing this? Thanks.
Reply to Location for main electrical panels in new construction in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
Hello, I am a homeowner and have a solar project coming up. I intend to install a 9kw solar system but I am not sure if I have to upgrade my main...
