If you were doing a "real" periodic i am sure the client would of noticed that any circuits on the said yellow phase were not working and also any 3phase equipment would of failed by now
Also its a ECIR now
Good luck anyway, i am out of this thread
OP,
As others have said, you need to provide explicit detail of all associated test equipment and switch gear being tested.
Pics would be even better.
Also its a ECIR now
You have a excellent point......but I have seen numerous largish 3ph installs with no 3ph loads. The one I'm doing at the moment has 5x 3ph DB's and only 2x 3ph loads
Agreed High Tower (i also have come across this, only once in my time though and that was in a pub/carvery)
But from my point of view i have never come across where anyone would do a Ze on a periodic inspection where any kind of fault would not of been noticed prior to that inspection (unless the yellow phase did not supply any circuits (very rare in my opinion)
I do hope the original poster posts again so we know the out come and anyone that reads this thread learns a bit more
Not saying that it was great in any way as I would definately do it different but I once came across a 3p board that had one of the supply cores split by a contactor to control the supply to storage heaters so very unbalanced but this could be what is going on here maybe.
That's a coincidence. Just done one yesterday. 3-phase intake. One phase out, nothing connected to it. so hasn't been noticed.
Strangely enough, it does appear to happen, although it was only the second time I've come across it.
