Discuss lv downlighters and insulation in loft in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
haj
Hi respected friends, With regards to LV downlighters into loft space what is everbody doing about insulation ? what is the correct procedure for dealing with insulation a foot thick ?obviously you need to keep the tranny clear and cool but what else should be done ?. :confused:
Cheers Friends :)
Re: Haj
I had the same problem and fitted insulation support boxes that came flat pack.Made up they fitted between ceiling joists and insulation was rolled over them.
thanks Jason. Puts quite a bit on top of the price may be hard to sell to the customer but the job needs to be RIGHT.
cheers :)
Make a 500mm chimney of plasterboard and baton Cut some 2 or 3 inche holes in the top/sides and plonk them over the fittings
Simple and cheap
Reply to lv downlighters and insulation in loft in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi guys New build small 2 bed bungalow to have 300mm of insulation in loft space. Obviously all circuits to be ran in loft and dropped. Circuits...
4K
Hi guys, I am new to the forum so be nice! I used to install solar PV systems back when the tariffs were still good, and I've never had to go...
5K
Hi All, I am not a sparky at present, I work in engineering, but I am considering a change. Last time there was a global financial crisis...
Hi all, Apologies if this is in the wrong place. I was wondering if anyone had any advice for me in regards to where to begin my search for a new...
