Discuss lv downlighters and insulation in loft in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
haj
Hi respected friends, With regards to LV downlighters into loft space what is everbody doing about insulation ? what is the correct procedure for dealing with insulation a foot thick ?obviously you need to keep the tranny clear and cool but what else should be done ?. :confused:
Cheers Friends :)
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
A
amicus
Re: Haj
I had the same problem and fitted insulation support boxes that came flat pack.Made up they fitted between ceiling joists and insulation was rolled over them.
haj
  • #3
Amicus how much did they cost you ? cheeky but if you dont ask you dont know
haj
  • #6
thanks Jason. Puts quite a bit on top of the price may be hard to sell to the customer but the job needs to be RIGHT.
cheers :)
J
Jono Pashley
No reason why you couldnt make your own support out of MDF or something similar.
Des 56
Make a 500mm chimney of plasterboard and baton Cut some 2 or 3 inche holes in the top/sides and plonk them over the fittings
Simple and cheap
uHeat Banner - Forum Discount Available
Reply to lv downlighters and insulation in loft in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
CK Tools :) The professionals choice when it comes to Electrical Tools
Top Bottom
