- Reaction score
- 0
Hi can anyone help me with some info? Im having to make my own double set in 100 x 100mm trunking and haven't got a clue. Need to know how to do the measurements please. Any help would be appreciated thanks
Discuss Making your own trunking double set in the Electrical Forum Canada area at ElectriciansForums.net
Im in industrial alot and pre-manufactured pieces dont often fit i take about 20mins to fabricate any doubleset and with pop rivets and a drill attached wire wheel i can make any angle look more professional than most factory made pre-fab bends.Total waste of time fabing your own sets ,good for practice but takes too long and they look crap compaired to manufacturers products.Most electrical specs.only allow manufacturers componnents anyway
yours benji
yours benji
inside bend; cut out of one side a 22.5 degree V & leave back intact, folding one over the top of the other so you have an overlap on the sides ~ pop rivet or nut & bolt.
Outside bend; cut off at 22.5 degrees then on one piece fillet the corners so the sides & back enter the other piece, then you flatten the back fillet to lie against the back of the other side, pop rivet or nut & bolt ~ Simples.
Alternatively braize ~ used to be a requirement within chemical plants when using stainless.
yours benji
yours benji
Can't agree with you on fabbing your own sets, getting round some things with the manufactured units can look just as crap actually putting sets and bends in trunking and tray is becoming a lost art like quite a few other things in the electrical industry
Reply to Making your own trunking double set in the Electrical Forum Canada area at ElectriciansForums.net
