Max. Distance for an unsupported flex from a clik ceiling rose to a light fitting. Can anyone point me in the direction of the Regulation number?
As I am sure you are aware, a lot of lighting circuits can be wired in 1.5mm2 and 2.5mm2 however it would be a very rare occasion to see flex of that cross sectional area serving a light fitting from a klik, hence why there is a stipulated max length for the flex.
From memory it's 2 or 3 metres. I don't know if it's the same reg but there's one which states a maximum length of cable which can be used where the csa of the cable is reduced, without fusing it down.
The fitting is supported by a ceiling grid. I could swear that there is a reg that stipulates the max length.
Well seeing as you are doing electrical work you have a copy of the regs.
You now have two options either understand the regs and find it yourself, or find a job that you know what you are doing when given a task.
Please can no one ever ask a question on this forum again!!!
how helpful...... Not.
Max length of unsupported flex to a light fitting.
atm84,
GEOFF S,
