Discuss Maximum Branches from Socket on Radial that's acceptable. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
What would be the maximum amount of Branches from a Socket on a Radial that you would find acceptable?
I've seen 4
I'm not talking about Design or being Tidy or keeping it nice for testing but how many would you say No that's just too many?
Are you referring to sockets on a spur off a ring final circuit
As far as i understand it, if it is an unfused spur then only 1 double gang socket is permitted
If using a F.C.U then I think you can have as many as you like as the cable is over load protected by the fuse in the F.C.U.
If more sockets are added to an unfused spur there is no overload protection for the cable, and it can be easily overloaded and is therefore a fire risk
If it is a radial circuit, then the practical limit will be the maximum conductors that can be terminated in a socket's terminals. Other limits are the total load on the added branches, given the maximum current set by the Circuit Protection Device.
Agreed. It doesn’t matter as long as the cable and OCPD are correct.
One in, one out is best practice.
a lighting circuit is a radial. Looping in at switch or ceiling rose is designed as one in, one out.... but the old JB could have any number of switches being fed from one live cable
Personally 1 or 2. This is very common in French wiring systems and presents a cauchemare as the French say in terms of testing, so the less the better I would say. I am not aware of any limit in BS7671 to branches in radial circuits. If you are discussing Ring Final Circuits there is a nice diagram showing how many spurs one can add to such a circuit which is finite.
There is a limit isn't there in France? or other European Country's?
Reply to Maximum Branches from Socket on Radial that's acceptable. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello Electrical world. Looking for thoughts and opinions. Currently planning out my kitchen re-wire for new kitchen. I was originally...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi! I've got a couple of 32A Wago clips. Creating a spur socket from a ring circuit with these is quite easy, but I wanted to know if it's...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
Hi all, Was wondering if you could help please. I'm looking to fit a BG IP66 external socket mainly for occasional jet wash/vacuum usage and...
