i know its seems mental but it the way i was told how to do it by 2394/5 tutor
doing it this way the average house comes out at 145 ish, an its funny to think most are fused at 60/80
why where they teaching u how to calculate maximum demand on the testing course ?
I don't know about you but when i getting shown something i have never asked why are you showing me this, guess someone must have asked! Thanks for your positive input anyway mate
try rapidtables.com kva calculator , but in my opinion 200amp 3 phase supply is plenty and if you ask for a 400amp 3 phase supply when the builder gets the price in he will stick with the 200
Sorry Iameletric just noticed you posted the same web site :) I guess the prob you've got is having no gas I did some calcs for a 2 bed flat with no gas max demand was about 80amps just hope they don't cook a sunday roast with all the trimmings and then decide to have a shower with all the heater on and make a cup of tea :laugh3:
Isit not 1.73
Try it on a calculator then confirm on the link a few posts back...
73Kva / 0.73 = 100amps (ballpark) actual long calc method approx 105amps
100amps x 0.73 = 73Kva
It doesn't work with 1.73 don't mix my quick method up with other methods where 1.73 is used as a cube routing factor of 3ph.
As i said it was a easy onsite method to use with one equation answer.
So if I have 125A on each phase , 125 x .73= 91Kva each phase ? Yes ? Ok
if I got a machine and it said 324kva over 3ph , would = 324 x .73 / 3 = 78.8kva per phase, ah fuk it lol
- - - Updated - - -
Il use my converter if I ever have too
- - - Updated - - -
Machines which are 3ph will give a Kva rating per phase not across 3 phases so you above machine would be stamped 108Kva
Come on IPU i clearly give kva to amps as division and i know you must be on the wind now as i know from your time on here your not stupid :smilielol5:
If you convert KVA to amps you divide not multiply 0.73
So your sum if you ever did find a machine with a total rating across the phases -
324 / 0.73 / 3 = 147.95amps.
well its a quick method for most God help the generation when the internet breaks down and they have to go back to maths ;)
Went to large flat last week. When I traced feed to CU it was fed from a 40mcb tenant been there 5 years never had any probs.
By writing a load of jumble, I found out you would never get amachine with kva for 3ph.:)
You do but not often usually found on imported Japanese machines sometimes or the likes it can at first be a pain to figure out the actual demand without load assessing the different parts of the machines... most machines will give max demand in amps but large machines with big heating banks tend to be Kva.
You stick to the original then
S[SUB](kVA)[/SUB] = √3 × I[SUB](A)[/SUB] × V[SUB]L-L(V)[/SUB] / 1000
I'll stick to my onsite quick calc' KVA / 0.73 = roughly same as above :)
