OP
iamelectric
try rapidtables.com kva calculator , but in my opinion 200amp 3 phase supply is plenty and if you ask for a 400amp 3 phase supply when the builder gets the price in he will stick with the 200
Discuss maximum demand kva 3 phase in the UK Electrical Forum area at ElectriciansForums.net
Isit not 1.73
Machines which are 3ph will give a Kva rating per phase not across 3 phases so you above machine would be stamped 108KvaSo if I have 125A on each phase , 125 x .73= 91Kva each phase ? Yes ? Ok
if I got a machine and it said 324kva over 3ph , would = 324 x .73 / 3 = 78.8kva per phase, ah fuk it lol
- - - Updated - - -
Il use my converter if I ever have too
By writing a load of jumble, I found out you would never get amachine with kva for 3ph.
After using the OSG for diversity have come up with the following
no...not the size of the main fuse...yes the size of the main fuse
this is a common and incorrect statement that i often come across on forms..
you can use your intuition to guestimate what the max demand will/should be...for a average 3 bed house i put down 60A...for a smaller 2 bed house i use 50A-60A...for a flat or say a back to back on 2 lifts with shower i go for 40A-50A
you can also take a direct measurement using a current clamp with all the appliances/loads that could be expected to be on at the same time...so for instance the shower, cooker and stuff like TV and some lighting...you clamp the tails...take a direct reading.
or as has been said above already you can go for a calc such as the highest load (typically a shower where theres no diversity allowed for an instantanious water heater)...then 40% of the rest.....
either way you wont get 100A
are you with 100A/whatever the bullit is?are you serious?
Reply to maximum demand kva 3 phase in the UK Electrical Forum area at ElectriciansForums.net
