R
RUSSMAN4
Hello folks ..
MEGGER LOOP TESTER LT300 EN BS MODEL (MAINS PLUG LEADS MODEL )
LT300 Loop Tester
The LT300 combines high current-loop testing over a wide range of frequencies and supply voltages with simple operation. This is a HIGH CURRENT ONLY tester, designed for installations where there are no RCDs installed. A two-wire test performs a fast loop impedance measurement at a test current up to 27A, with a resolution of 0.01ohms. Frequency range and operating voltage are wide, allowing for a diverse range of applications up to and including CATIV 550V phase-to-phase. Testing commences automatically as soon as the instrument is connected to the supply. Repeat testing is provided by the TEST button.
Used , but in good servicable condtion ..
£100
or best offer . Will post , via insured courier , for £10..
Tel russ 0n 07904022886 , located in surrey
LT300 Loop Tester
- High current loop tester
Simple auto start operation
16Hz to 400Hz frequency range
Up to CATIV 300V phase-to-earth (550V phase-to-phase) applications
£100
