Discuss Megger not working in the Electrical Tools and Products area at ElectriciansForums.net
Hello
Hoping somebody can help. I have a Megger MFT1552, whenever I turn it on it beeps and flashes 138v (detecting voltage) Even with no leads attached. Has anybody came across this before?
I had trouble with my 1552, sometime the sleeve where the test leads plug in come out a little with the leads giving false readings. You can push the outer sleeve back in using screwdriver gently.
Hello
I had something similar with my 1730 on continuity testing, leads attached but not connected to anything.
It was a problem with one of the terminals and had to go back to Megger. £280 later it can back fixed.
had same problem with 1553, cotton bud and a bit of switch cleaner in the 4mm sockets. cost 20p.
Reply to Megger not working in the Electrical Tools and Products area at ElectriciansForums.net
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
I plugged a drill press directly into a GFCI outlet in the garage. Something blew up by the drill press switch. Since then the GFCI outlet LED...
So, I got a level 2-3 electrical installation diploma fresh out of college with no experience especially onsite. I was wondering whether working...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
