Discuss Metal conduit earthing System questions in the UK Electrical Forum area at ElectriciansForums.net
V
Virtus Lucem
Hello Guys,
I have a question for you on metal conduit earthing systems. I've been asked to upgrade the CCU on my wife's grandpa's 2 bed flat (bit of a love job so I want to keep costs down). On inspection I've discovered it's an old Imperial metal earth conduit system. All the EFLI values are well within range for the 3036 fuses protecting it and the Zs at DB is 0.15. My main concern is the main earth and main bonding. The steel conduit supplying the main tails is used as the main earth, obviously this is fine and safe complying to the old regulations, but if I update the CCU to another metal CCU will the installation comply to the 17th using the steel conduit as the main earth? If I can what would I put on the certificate as to the size of earth?
It's a 5th floor flat and the conduit disappears into the concrete floor so running a 16mm earth from the supply isolator would definitely take some further investigation as I don't think I would get a 16mm down the conduit. Can I use the existing conduit and comply to regs or not?
Also there is not water or Gas bonding that I can see however there is continuity to the earth terminal and a nice low reading. how did they bond in the good old days? Luckily the gas meter is in the same cupboard as the CCU so I can easily run a 10mm to it however to the water inlet would again be more involved.
One more thing is the flat has an old warm air heating system do you know the likelihood of asbestos in the heating system?
Cheers!
Asbestos - unless it has all been removed, then expect it anywhere. Do not drill anything unless you know it is not asbestos.
No problem with the conduit being the CPC for the sub main, so long as it is in good condition.
Water bonding - probably has been done at the intake, I'd be tempted to put a 10mm cable in to the internal water stop-cock in the flat, just to be sure.
Have you considered reading the regulations concerning the use of steel as a cpc before asking? Yes steel conduit is still the cpc for the circuits contained within it, that has not changed. But due to electromagnetic effects you do have to apply a correction to the measured impedance in some circumstances
Reply to Metal conduit earthing System questions in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I'm nearly on my AM2 test and really enjoy the industrial side of things so I thought I'd learn by asking. I recently came across...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
