Discuss meter tails 16mm 10mm earth in the Australia area at ElectriciansForums.net
hi guys got a cu to change from the meter to old cu there is 16mm tails with 10 mm earth
as the meter is locked off with crimps & wire
what is the proper way off changing the tails to 25mm and 16mm earth
can I chop and get into the meter without any come backs ?
or can i leave it as it is on 16mm tails & 10mm earth reason why i,m asking is i dont think the 16mm earth will fit in the earth terminal on side of main fuse income.
1 x ring up/down sockets
1 x ring celler sockets
up lights
down lights
celler lights
cooker
cheers jon
what's the supply fuse rating? and what earthing system. sounds like TNC-S. IMO safe isolation overrules cutting seals. since deregulation, suppliers don't seem bothered any more. are you sure the seals have not already been removed?
100amp fuse yeah tnc-s system wink wink eh
thing is though i still dont think the 16mm earth will fit in connector on side of meter? 10mm just fits in. i checked as i had some on van
you mean on side of cut-out for TNC-S surely. for 100A fuse, you really should fit 25mm tails.
Reply to meter tails 16mm 10mm earth in the Australia area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi I have a domestic installation to rewire and the main incoming fuse is 80 amp so i am using 16mm double insulated tails, is the main earth size...
Hello again, Was looking at installing yet another dedicated consumer box for my EV charger off the henley blocks and i noticed that a meter...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
