Discuss Meter Tails hanging loose. in the UK Electrical Forum area at ElectriciansForums.net
Been to a job to see this. I'm guessing that when the old CU was replaced the sparks didn't bother to remove the old meter tails - they were live and just had a couple of wraps of insulation tape round them.
Yup the Neutral cable is ok with black tape. But black tape on the live red cable! Why they couldn't be bothered to use red I can't imagine.
What I don't get is it would have been as easier to remove from the henley block than a consumer unit?
That's it - they'd taken out the DNO fuse (and hammered it back so the prongs were bent out of shape) so why not take the old tails out the Henley block? Been like that for years apparently. Customer has certs for the CU - installed 2011.
I don't suppose the terminal screws were sheared off. What did you do, me I would have whipped them out.
Yet another adjustable earth clamp on the DNO cable.
Hello,
Upon visiting the site and performing some testing and inspection it has been found that all four of the CT’s installed in the starter cubicles are over heating. The burden is 2.5VA , ratio is 20:1 A @ Class 1 CT.
What might be the problem? Please help
Hello,
Wrong thread ?
Reply to Meter Tails hanging loose. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
Hi, Just had a new Smart Meter fitted yesterday along with isolator. The chaps installing the SMART meter used 16mm tails from the main DNO fuse...
8K
