Discuss Meter tails in ceiling ? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I am moving a CU from next to the meter to about 1.5 meters away on an adjacent wall. Am I OK to run the meter tails through the ceiling void between the joists (plasterboard ceiling) to the new CU position or is a case of installing an isolator and 25mm swa?
Many thanks
Personally I would be going with a switched fuse, this would allow for a point of isolation and afford the tails some protection rather than relying on the DNO fuse.
Dependant upon the installation method you might be fine with running the tails as they are if not either RCD or SWA.
Then I don't see any technical reason why you would need swa or a switch fuse.
Thank you for response, I just wasn't 100 per cent about the tails being in the ceiling. So as long as they are coming down the wall surface or are buried at more than 50mm in the wall then that's fine as well?
Unless the meter is already at a high level I find it hard to believe the tails will be 3m or less as I generally find - from external meter box to ceiling = 2.5m (includes 0.5m through cavity wall and in meter box)
In ceiling (from what I understand from your post = 1.5m
From ceiling to repositioned consumer unit 0.5m (min)
Total = 4.5m
As above, 3m of wire gets used up surprisingly quickly!
I would really check/measure the distances involved first. Have you got pictures and/or a drawing of the planned route?
Total = 4.5m
Yes the meter is also at high level, but yes you're right I will double check the measurements its going to be close to 3m that's for sure
Reply to Meter tails in ceiling ? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
Where do people record the Ze & PFC of a 3 phase installation, if there is say 10m of 25mm tails between the 4 pole isolator (next to the meter)...
