Discuss Meter tails through Recessed meter box in the UK Electrical Forum area at ElectriciansForums.net
TheCodboy
Hi all, what are your thoughts on running new tails from an outdoor recessed meter box,straight through the existing hole into the garage where the CU is situated. Should the hole be enlarged to accommodate some sort or trunking for protection and sealed for fire??? The tails are connected to a DP isolator and the CU is within 3 meters.
Seal the hole for
Would of thought that would be the DNO's responsibility.
i'd prefer todrillout the hole in the wall and bang in a piece of 1 1/4 waste pipe, available from any plumber's stockpile.
Straight through the wall then clipped direct or trunking wouldnt req rcd protection, however a sleeve would stop damage to cables from falling debrie down the cavity in the future.
Is this garage attached or integral always protected tails in trunking (mechanical protection and neatness) never known the hole being sealed in past but see no reason not to.
If the board is mounted on batons and ply,bringing it off the wall, do you guys believe that it is ok to bring the tails into the rear of the CU with the other cables? The tails would be supported by being clipped within the trunking its contained in with fire clips. Or just go with a tails gland into the bottom/side of the CU?
i'd go in from the bottom. that way you can clamp the tails if you need to for load or for finding any earth leakage.
What about the batons and wood board mounting? i know that its only the CU that needs to be of a non combustible material, i just dont fancy getting it all done and them someone telling me that i need to loose the board and batons!!
Reply to Meter tails through Recessed meter box in the UK Electrical Forum area at ElectriciansForums.net
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
We had a new supply installed this week. DNO installed new cut out and fuse externally. Meter operator sent his engineer to move the meter in the...
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
