Discuss More than one circuit on breaker in the Australia area at ElectriciansForums.net
R
Richard3009
I have found in my house on the downstairs ring main that three lives are terminated into the 32A circuit breaker, two are for the ring main as you would expect; the third is for a socket below the fuseboard, to all intents and purposes its just a spur and electrically wise its sound.
Just wondered how this stands up with regs having three conductors in the breaker.
my understanding of the regs, from memory mind, is that a spur can originate from a termination at a socket outlet, a junction box or at the origin of the circuit.
yes, would agree with wetstring - it is acceptable to have a spur on the circuit from the consumer unit in this way.
Never done it on sockets, but it is a good way of adding an outside light on a lighting circuit if there are no spare "ways" in the consumer unit.
then i would see that individual socket as more of a radial being served directly from the breaker in this way and i wouldnt have a 32 amp radial on a 2.5 t/e :confused:
if i was designing a circuit being fed from an mcb directly to a socket irrespective of what other cables were in the mcb already i would see that circuit as a radial, not a spur.
26a cable and 32a breaker :confused:.
i see where your coming from spurring from existing socket etc etc but not from board.
just my opinion ;)
its not a radial, you can't have more than one double 13A on it, a radial you can providing the conductor size is correct for the potential load.
didnt mean you tiger, was asking richard. ;)
dont forget Ib has to be equal to or greater than In when selecting a cable richard.
point me to the correct reg and i will stand corrected :confused:
If there was a radial circuit from a 20A MCB then thats fine
If there was a "spur" from a 32A RFC MCB then that is also fine.
It is no different at all to taking a spur off the back of a socket or at any point in the ring via jb.
Pg 362/3
Reply to More than one circuit on breaker in the Australia area at ElectriciansForums.net
Last year we purchased a home that was built in the late 1990s It has one outbuilding, sort of a barn/shed about 160 feet from the house (and...
  • Locked
5K
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
