K
klunk
Hi, help please.
I'm moving an electrical socket, only a few inches, and want to use the existing box as a connector/junction.
Is there a specific connection product, on a blanking plate, or should I use block connectors?
Or should I buy a junction box, and plaster over. In which case what rating, for one socket? (for dishwasher)
Cheers.
If you do use the existing accessory backbox as the enclosure for the joint & it remains accessible after the fact, any type of suitably rated connector can be used i.e, screw terminal connectors, wago connectors, helaconns etc etc.
I would favour the above method of using the existing backbox with a blank plate cover over that of using an additional joint box.
As I said, make sure you use the correctly rated connectors.
