Discuss Moving MASTER Phone point in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
TPES
I've got a MASTER (Old NTL) Phone point to move.
Just wondered if anyone has ever had any trouble doing this? I know most people would prob leave moving a master point to an NTL engineer.
I have no problems at all with BT Points, Adding/Moving, Just wondered if theres alot of hassle in moving a master NTL (Virgin Media) Phone Point.
Im helping someone out who is having an extension and the wall with the master point on is being knocked down. so point needs moving.
Im guessing its going to be as simple as most phone points.
what do you reckon ?
I used to work for NTL.Where is the point being moved to.Go to the omnibox outside the house and you should see the 2 blues-blue and white/white and blue scotch locked to the master socket.Just run a new cable from the omnibox to where the master will be and if there are any extensions then connect accordingly.Make sure you connect a ringer on the extensions,i use the orange and white if there are no capacitors on the extensions.If there are then you only need to connect the blues:D
Thanks Mac..
I dont think its moving far, Ill come back if i get any trouble.
Does anyone actually take notice of what you are allowed to do when it comes to BT??
No:D
Only trouble is if you have a fault with the line at some point.
They MAY charge for repair if they discovered its been moved and not installed correctly.
Just a possibility thats all.:)
I Know some sparkys that dont care, and i know some that wont touch a master socket.
As jason said, Your not really supposed to touch there master sockets as its there property, they might get funny about it if ever called out in the future. But i suppose if any works been done and its right they wont even know.
If its a BT master, then you are not allowed to move this as this is their equipment.
Not sure about NTL though.
If it's in your property you can do what you want with it.They just don't like you messing around with the box outside.What the eye don't see the eye don't know.BT and Virginmedia would charge a small fortune now to move a point:DHow are they going to know you have moved the point.
Reply to Moving MASTER Phone point in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello, No formal certification here, just grew up watching my Dad and Grandfather do things on their own and learned a little in schools and most...
Hi, Apologies if a lot of this is pretty obvious, but my knowledge is fairly limited. We just had a Master Socket 5c MK 4 fitted (downstairs)...
10K
Hi I am a sparks from the 15th Ed, did 16, 17 and last year 18th. I am out of practice though as have been office based for 12+ years in a...
Had a call this morning, customer come back from visiting family and during the recent up and down weather it appears rain has got in and damaged...
12K
