Discuss Multiple circuits passing through an AC isolator in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Multiple circuits passing through an AC isolator what code is this on a U.K E.I.C.R?
Welcome to the forum mate.
As above, more info is needed.
Out of curiosity, after telling us more about the situation, also tell us what code you think it should be and what regs it contravenes.
It’s a 3 phase isolator with 2 circuits passing through it 1 supplying the isolator I.e 7L1-3 and another circuit 8L1-3 passing through it and on to another isolator 1 meter away
What risk / danger / non compliance do you see and what code would you give it based on your observations?
Reply to Multiple circuits passing through an AC isolator in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
Hi, just wondering if I have a cable passing through "100mm insulation at 2 points", do I use the correction factor of 100mm at 0.78 or 200 at 0.63
We don't normally do PV, however I was called to a PV inverter with no power, 6 years old Found supply OK, however fed through a AC type RCD. PV...
4mm T&E circuits on 32amp breaker. Parts of the circuit run through ceiling, parts through trunking and possibly even the wall. Current carrying...
