J
Jabbajaws
Has anyone seen the experiment on Mythbusters where they investigate, whether or not a person would die, if a person was having a bath and an electrical appliance were to to fall in the water?
It was very interesting, though it has raised certain questions. Let me give you the facts.
The Mythbuster Scientists constructed a special bathroom for safety & also testing reasons.
A dummy was cast from Ballistic Gel (whatever that is) as it is supposed to be the closest artificial substance that resembles human flesh.
The dummy was then placed in the bathtub, full of water.
Above the bath was a collapseable shelf, on which the appliance being tested was placed, and this shelf was activated by a 6V relay.
The bath was grounded, as americans refer to it, otherwise known as bonding to us, so that the ammeter, that was placed around the earthed bonding wire (attached to the metal framework of the bath) would measure the amount of mA that would flow to earth, during the test.
They were advised that 70mA was enough to cause death. After performing several experiments, they sought advice from a professional electrical expert, as they called him.
He then told them that a mere 6mA travelling across the human heart is enough to cause death.
They then inserted two copper plates, one either side of the dummy's "heart" and attached a test lead to both plates, which led to an unidentified test instrument that l couldnt make out what it was.
They then proceeded to drop several appliances into the bath, measuring the amount of mA across the plates, as they had been told that 6mA across the heart causes death.
I am confused by this. This appears to look more like capacitance than an amperage measurement to me.
Can anyone explain this to me, how they can measure amps across the 'heart' by using copper plates? I just dont get this.
And can anyone support the '6mA across the heart is likely to cause death argument'? Im sure thats wrong....
