Discuss New Zone on central heating. in the Central Heating Systems area at ElectriciansForums.net
I have just fitted a new Zone on the central heating and need to wire it up. The new Zone will be controlled by a Carel S90 digital thermostat. Where the Zone valves have been fitted, the timer/thermostat cable runs past, so I've cut into the cable and it has 2 lives, earth and neutral. Because we hardly ever use hot water the existing timer is always in the OFF position. This means there isn't a constant live in the cable that can be used to power the new thermostat. There isn't a constant live at the boiler either.
So I need a live to power the new thermostat, what's the best way of getting power to it?
Run a separate permanent live conductor from you heating wiring centre (big junction box) to the thermostat. Don't be tempted to pinch it from elsewhere.
I've currently not got a large junction box as there were no valves originally in the system. I'm going to run a permanent live from the programmer I think.
Thanks.
Reply to New Zone on central heating. in the Central Heating Systems area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
Hi all, my condenser boiler central heating has started to do strange things so I set about trying to diagnose the problem. When I got to the...
4K
Hi everyone, my house has an air-to-heat system that generates hot water in a boiler. This boiler is then connected to the central heating...
