Hi all,
first post here, let’s go.
So I’m installing a smart switch in my kitchen and after pulling the existing switch out I noticed that there are only two cables in the wall box. Each of the two goes to the switch with a simple straight connection. I’m assuming that these are both live wires. This would mean that I don’t have a neutral or a ground wire. I can’t install my smart switch without at least a neutral. How should I proceed?
Picture attached
you either get a neutral in there if possible or exchange the switch for one that doesn't need a neutral.
is there no way to make one of those live/load wires into a neutral current? Trying to figure out what my easiest/cheapest solution is (maybe there isn’t one)
thanks
No you have a hot in and hot out. New wires are required, a neutral and a ground if your new switch requires it because your existing one does.
Long Beach Ca
United States of America
Trainee Electrician
No neutral wire for smart switch?
Lighting Forum
Opatry,
westward10,
