A
AndyOz
Always use contractors you already know
Auto spell correction is a wonderful thing,
Discuss Old Mill Electrical Installation in the UK Electrical Forum area at ElectriciansForums.net
so you think the enclosures doesn`t count here then?So you think the exposed live connections are ok? Code 4? Is the report quite old then?
I also served my time working on boards like that, and still have the scars to prove it...
but emptyheads shouldn`t be going into enclosures ...should they...Dont get me wrong they deffo recommend for change but if the doors are secured by wing nut fasteners then access can be gained without a tool and the exposed live parts are then a issue for you to make good temp' as anyone on site could put themselves in danger i would take a few minor steps like fitting a padlock and giving the key to the foreman/boss while you file your report and send it in..... if anyone gains access in the mean time you have taken steps to limit this so keeps you in the clear.... it also heightens the need to replace them to the client.
Because you can close the doors i would recommend at a minimum you fit an appropriate warning label warning of the dangers in access to the board.
If you found accessable exposed live parts in a domestic install it would be down to you to make this immediate danger safe whether a temp measure or not while you file your inspection report.
Me too ! On that note do you know where I can find a VDE zimmer frame?
no safe iso then?
I've left you mine in my will .............. Just be patient !!!
Reply to Old Mill Electrical Installation in the UK Electrical Forum area at ElectriciansForums.net
